HDR2 with Beovision 3
If I want to use an HDR2 with a Beovision 3 (32) do I need a software update for the Beovision?
Currently there is no "HDR" option in the connections menu.
HDR - V.Tape/V.Mem
Ok so I've got the HDR2.
I have connected it up as per the user manual to Beovision 3 (32") and Panasonic sky box.
The HDR2 is registered in the Beovision as "VTape".
The sky box was previously operated via the Beovision STB controller with no problems.
The HDR2 seems to work generally as the manual suggests except I can't get the sky menus via the menu key, the instant record (hit record twice) doesn't seem to work and the sky "direct control" i.e. go 1 for viewing guide sometimes works and sometimes doesn't.
Also if I leave the Sky box connected to the Beovision I don't get STB as an option when programming a recording on the HDR2
Any tricks or tips to fix these problems?
