HDR2 + B&O DVB-T module
Does anyone actually have the HDR2? Is it simple to record content form non-B&O STB or B&O DVB-T module (on BV8)?
Or, is it better to wait for B&O to incorporate a digital tuner(s) in HDR2?
B&O claims HDR2 is easy to use with external STB, but is this really true?
If I press "record" or record-record (like in V8000), will the HDR2 actually start recording from STB or DVB-T mobule?
  1. Does anyone actually have the HDR2? Is it simple to record content form non-B&O STB or B&O DVB-T module (on BV8)?  YES
  2. Or, is it better to wait for B&O to incorporate a digital tuner(s) in HDR2? Most likely better to wait.
  3. B&O claims HDR2 is easy to use with external STB, but is this really true? YES.
  4. If I press "record" or record-record (like in V8000), will the HDR2 actually start recording from STB or DVB-T mobule? YES - It will even perform timer recordings and turn the STB on and off automatically.
Roger
Roger,
Thank you!
Sinuhe
