HDR1 use with BV3
I currently use a Beocord V8000 with my Beovision 3 and it all works well. I have the chance to get a HDR1 at a good price. So the question is will it work OK  with my Beovision as it is or will I need to update the software? The Beovision is about 5 years old.
Phil
The HDR1 worked with my much older MX7000 so there will be no problem with your BV3. The HDR1 is only incompatible with the AVANT with an integrated V.TAPE.
HDR1 is seen as a VX8000 by the TV so no problem.
HDR1 is a great recorder. It has a STB-C on the back, so if you don't have one on the TV you could connect a STB to the AUX scart of the HDR1 and control everything with the remote.
Otherwise you can connect the VX8000 to the AUX scart of the HDR1. You can call it by pressing V.TAPE + YELLOW and then you control the VX8000 with the Beo4.
You can even transfer recorded programs from the HDR1 to a tape on the VX8000 for archive. It will start and stop automatically. Pure B&O magic.
p.
It worked absolutely fine with my MX.
Are you aware of any problems with the BV3?
p.
That's great, thanks for the info.
Phil
I haven't any experience with the BV3. But I expected that will be no problem at all.
Both the 28 and 32" version are avant related.
One thing you should do is to attach the HDR1 directly to the BV3 and not at the decoderscart from the V8000.
First attach the HDR1 to Vtape scart without the v8000 attached at all.
In this case you will have for certain a "tunerdump" between the BV3 and the HDR1. This is needed for the right tunersettings in the HDR1.
If you connect the HDR1 behind the V8000 then there will be certainly no tunerdump.
So you have 2 options
Connect the HDR1 to Vtape socket on the BV3 and the V8000 to AV socket as Vtape2.
Or connect the V8000 to scart at the back from the HDR1 to AUX (I thought it's called that way) and name it in the menu from the HDR1 as Vtape.  Then from the main menu the V8000 will be accessible via of the color buttons on the Beo4.
In the latter example, the record record function will result in a recording HDR1. Programming via teletext is also possible.
Is there a way that I can have the V8000 connected to HDR1 but still be able to record from my STB onto the HDR1?
Have you got a STB-Controller (or PUC) on the BV3? Have you got a DVD1 or another source connected as well?
If yes, then you connect the STB to the TV to the AV Scart and use the STB-C, the HDR1 to the V.TAPE scart, and the V8000 to the back of the HDR1.
I include here the result of the B&O recommendation made using the PCG, for using a STB, HDR1+V8000 and a DVD1
************************* VIDEO SYSTEM SETUP **************************
BeoVision 3 - 28" m/ML
HDR 1 (VR 1)
V 8000 (VR 2)
DVD 1
Set-top Box Controller ( 1 STB )
Connection Video
Connect the aerial to the aerial input of the VR 1.
Connect the aerial output of the VR 1 to the aerial input of the
TV-set using a coaxial cable.
Setting of switch on DVD
Set the switch on the back of the DVD 1 (Y/C - CVBS - RGB) to position RGB
To ensure that the DVD discs are played with the proper picture format,
please perfom this "once only" operation:
Press LIST on Beo4 until v.setup appears in the Beo4 display.
Press GO to display TUNE. Press 1 if the DVD1 is connected directly
to a BeoVision MX television.
Press 2 if the DVD1 is connected to a BeoVision MX via an AV2 Expander box,
or if DVD 1 is connected directly to any other Bang & Olufsen television.
Press GO to store the setup.
Default is mode 1.
Selecting option on the TV-set
Option: OPTION 1 (Factory setting), with Beo4
                Press:                          | Display:
                STANDBY + LIST at the same time | OPTION?
                GO                              | V.OPT
                1                               | Observe confirmation
                                                | from BeoVision
Programming the setup
TV Setup:
To get access to the CONNECTIONS setup menu do as follows:
Press  MENU
Select  OPTIONS  and press GO
Select  CONNECTIONS  and press GO
Edit the menu on the screen using ARROW UP, ARROW DOWN, << and >>,
until it looks as follows:
          CONNECTIONS
    V.TAPE  V.TAPE
    AV      DVD
Store the programming by pressing GO.
HDR 1 Setup:
Connected sources should be set up in the following way:
         V.MEM / MENU / Setup / Connections
Choose the following from the menu:
   V.TAPE
Note!
On TVs with an ML kit it is only possible to connect a decoder to the
TV's V.TAPE socket or the DEC socket of a V 8000.
Only the V 8000 supports video signal pass-through from the decoder
to the TV.
********************* REMOTE CONTROL FOR MAIN ROOM ********************
The recommended remote control is Beo4
The following remote controls may also be used:
Beolink 1000
However, there may be functional limitations if the alternative
remote control is used
Setup for Beo4 remote control:
Beo4's "LIST" must contain the following items in order to be able
to operate the Main Room products.
STAND
CDV     (only with S/W lower than 4.0 in Beo4)
MONO    (changed to SOUND with S/W 4.0 or higher in Beo4)
AV      (only with S/W 4.0 or higher in Beo4)
See Beo4's operation manual page 10/12 on REMOVE and ADD functions
from/to the List
Note!
Beo4 must be equipped with software (S/W) 3.0 or higher.
The software version will be shown in the display of the Beo4 if you press
(STANDBY+LIST) at the same time, and (MENU+GO) at the same time.
