HDR1 and DVD1 with BV6-26
Hi!
It's been a long time since I was here, mainly because of a new job and a new apartment, which have taken quite a bit of my time.
Now, though, I'm ready to ask a serious B&O-related question. :)
I have a BV6-26 from 2005 with a DVD1 connected to it. (Some of you may recall my HTPC build, but unfortunately it broke down.)
Now I'm considering buying a HDR1 so I can record TV programs as well, since that's a feature that I'm currently lacking. I know that the DVD player is controlled from the Beo4 via the TV. Does the HDR1 work the same way? And can I connect both of them to the TV?
How do I go about this?
Thanks!
/Fredrik
Hi Fredrik,
there is a set-up guide
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
I used to have exactly this setup. I worked great. Offcourse with the HDR1 you cannot record digital TV so now on my new BV-8-40 I no longer use the HDR1.
