Hello everybody,
I will sooner or later add a 4x2 HDMI splitter to my BV8 40 setup, in order to get 5.1 sound with movies on my videoprojector (BV8 in P.mute, videoprojector for the image).
I thought of buying a cheap 4x2 matrix like that
Hello everybody,
I think it's only a Gefen one, and it costs about £400.
The BV7 (and I assume BV8 also) only supports 1 Geffen model which I don't personally recommend. It is outdated, expensive and less capable than newer splitters. Most other splitters auto switch and many come with remotes. My recommendation is Atlona. I use their 2 way splitter to switch between my Apple TV and PS3. Not in any PUC lists but still does the same as the Geffen as both my Apple TV and PS3 share V.AUX2 on the Beo 4/5 remotes so when I select one, the other switches off automatically and vice versa. Thus achieving full B&O remote control providing you have got your IR cables attached for further B&O remote use as with the Apple TV and PS3 in this example.
See http://www.futureshop.co.uk/atlona-technologies-c-306.html and call them for the best advice on all manufacturers, models and options available to you. They have considerable expertise and I highly recommend them.
All the best,
Simon.
Login to view image Login to view image
Thanks, I also thought that the Gefen was just an overpriced crap... I will take a look at Atlona, I didn't knew this brand.
Can you confirm that you never miss a remote? Or do you control the splitter with your Beo5? (What remote system do you use for teh PS3? I have a Nyko blu wave)
I can use both the Beo 4 and the Beo 5 remotes with the Atlona splitter. Everything works fine. My Beo 5 has been programmed for the PS3.
hi ,
do you know if this splitter also works for BV7-32 ? my BV7 32 mk 2 uses DVI for video and coaxial/rca for sound . i am dying to find an ideal splitter for it . please help .
The Beonic Man...What is the cost of Your Splitter please! Thanks!
I just added the Gefen 1x4 splitter to my BS3 and it works perfectly. The BS3 sends the codes to the Gefen splitter to change to the appropriate HDMI input for C1, C2, C3, or C4.
As the Gefen splitter is HDMI 1.3, I don't see how it is outdated in any way. Regardless, the BS3 is not even HDMI 1.3.
BeoJeff... its not outdated as such, just overpriced and not as future proof as other models available. Compare the specs below for example:
Gefen 1:4 HDMI Splitter
link
Atlona 1:4 HDMI Splitter
link
godotz... see this link to find the product you require:
I too have a BV7 with DVI and coaxial audio. Futureshop are still looking into it.
I have been recently told that some devices only carry stereo sound through HDMI. Foxtel IQ2 - SKYHD and Apple TV were mentioned... please tell me this is incorrect?... Otherwise it would mean a rather complex HDMI and coaxial audio matrix of switches...would it not?
beoaus.
