Hi Beoworl............
I have a 7-55 TV where I have used all 4 HDMI connections and all 6 AV connections, the setup is:
AV1 - Set top box (HDMI) + PUC
AV2 - Beomaster 5 (HDMI) + SP/DIFF for sound
AV3 - Internal DVB-HD (HDMI)
AV4 - Internal DVD/Blueray (HDMI)
AV5 - DVR (Video In)
AV6 - Wii
My plan is to keep both the Settop box and DVB-HD, and I have disabled the Internal Analogue TV Tuner.
I plan to buy a Tvix 6600 that I would like to connect with HDMI, but how does this work in real life?
My dealer does not know how the HDMI Expander works in real life, and also, how to use the PUC connections to the devices connected via the HDMI Expander?
Can somebody help here?
HDMI Expander
The recommanded Gefen HDMI switch is controlled by the PUC. Connect the HDMI out of the switch to a HDMI input of your BV7. Assign this port to "Expander". As far as I know the four inputs of the switch can be controlled by different PUCs. Maybe this helps:
http://195.173.140.100/Beoworld/HDMI_Expander_Guide.pdf
Oneremote also offers Beo HDMI expander. www.oneremote.dk
Hope this helps
Stefan
Is it the same HDMI expander working with BV 10?
Marc.
Yes.
Stefan
I have read the manual, but I am still in doubt. In the AVx connection in the TV I also use the PUC and SP/DIFF. So, if you add a HDMI extender, can you then still use the PUC and SP/DIFF, and if yes, to what HDMI Extender Input port would it then work on? Can you configure each port on the extender whether it uses HDMI only, PUC, SP/DIFF etc like in the TV menu?
I have tried to put all my boxes away.
..... Can you configure each port on the extender whether it uses HDMI only, PUC, SP/DIFF etc like in the TV menu?
I`m not sure, I don`t have an HDMI expander, and the manual is not very clear on this, but it wouldn`t make much sense, if this would not be possible....
Maybe someone who got the related sw can have a look in the connections menu....
Stefan
It's actually a bit simpler than that. When using an HDMI expander, there is a place on the BS3 or tv menu for you to select that an expander is being used. If there is not an option for that in your menu, you need a software update. Once you indicate on the menu that the expander is present, you will now have additional HDMI ports to select from when setting up your external devices on the menu. For example, instead of being able to select from HDMI A, B, C, and D; you will now be able to select from HDMI A, B, C1, C2, C3, C4, and D. You still use the external device set-up on the tv menu to select the appropriate PUC device and whether or not HDMI is also being used for audio. This is all already built-into the B&O TV or BS3 setup menu. It's not done at all through the expander. The B&O TV or BS3 automatically switches to the appropriate HDMI input on the Gefen expander.
Now, here's the part that might be confusing. Regardless of how many HDMI ports you now have available, you are still stuck with only 6 AV ports on the BS3 or B&O TV. You merely have from 7 HDMI ports to choose when assigning the HDMI port to one of the 6 B&O AV ports. Again, this is all done via the B&O external device setup menu. This means that you will have at least one HDMI port that is not being used.
These extra HDMI ports could still be useful if you have need for those extra HDMI ports. You can connect those "unused" external devices to the "unused" HDMI ports and then when you DO need to use those devices, they are already connected. You would not need to physically switch the cables. You would merely need to re-assign one of the 6 B&O AV inputs to that device and appropriate HDMI input via the external device setup menu. Still rather cumbersome. However, it seems feasible that a macro could be created on the Beo5 to do all of that with the touch of one button and switch it back at the touch of another button.
Hi Beojeff
Thanx a lot for your answer, exactly what I needed to know. I can see in my TV that the internal DVB-HD does not use an AV connection, so I still have AV3 available for i.e. the Tvix player connected via the HDMI expander. Great, this might be very useful.
And I can not figure out what else to be connected, so this might be the last connections to be made..............😁
Anyone got a link to where the Gefen HDMI expander can be purchased in the UK?
Thanks - S
is this only a BS3 platform function?
so that it is available for BV7s but not BV8s?
(also not for BV10 ???)
