HDMI EXPANDER FOR BV7
At least we should see a Type number change... and maybe the HDMI sockets on the back...
So, going back to the original topic, anyone got more info on the HDMI Expander?
Availability, cost?
Br,
Petros
The new panel for BV7-32 hasn't been realest jet, So you can't find it at your dealer, I think it also is going to have the same type of contrast screen as BV7-40 mk3 and BC6...
Hello Speaking to my dealer this morning and the HDMI expander is a readl product but i want to know if i run my sky hd and PS3 into the hdmi box and that then runs into the DVI socket
Where will my beomedia go as it currently uses the DVI.
Help
I am on the case and will let everybody know. On dealer said it is not HDCP compatible cna anybodty explain and does it affect this?
thanks
Vince
Surely it's HDCP compliant? HDCP is the copy protection protocol that is used by HD sources. It's supposed to ensure HD content isn't copied.
One question on the BeoMedia question.... I have the same problem, BeoMedia has VGA out which is currenly converted to DVI. But I'm not 100% sure you can go VGA to DVI to HDMI, I might be wrong but I am sure there is a problem in doing this.
Greg
HDCP is probably something like HD Copy Protection
It is way for a source (like a blue ray DVD or a set top box) to send an encrypted signal to the TV, so that it cannot be recorded.
Full HD or HD ready sets HAVE to be compatible to get the Logo.
p.
