HDMI EXPANDER FOR BV7
B&O has made an HDMI expander BV7 32 mk III and 40 mk II, so instead of 1 DVI input you get 4 HDMI input with the expander box.
If you have a 32 MK I or II,  40 MK I with the HD upgrade it's an MK III so think it also can use it.🙂
Would appreciate any further details; is it a separate box and how is it mounted and how much is it?
thanks
Vince
...and do you need to upgrade the firmware of the tv?
Yes TV need SW and firmware upgrade to 7.7 , it's a separate BOX, have to wait to it's in the shops and see haw it can be mounted on the TV.
thanks for info, but DVI is only picture how does sound get converted as well
any idea of cost and when is it available as well?
 thanks
Vince
How can you tell if your 7-32 is MK I II or III
Søren
I really, really, really hope this is true!
More details pls!
