Hdd-recorder
Hello Ian,
So you lose 17h recording time - But you gain a DVD drive
Exactly, but I have already 4 dvd players,  2 of them are dvd recorders.
 Regarding the STB-C situation - What does that mean exactly - It can't record a digital signal (from an external box)?
You can record from it, but you cannot control the external tuner box with Beo4, you must use its original remote to control the box.
But if you have the B&O built-in DVB-T module, that would solve that problem? There must be some limiting factor to the DVD2 to create the need for the DVD2 and the HDR2.
On new chassis TV (BV7, BV6), you can control the STB that is connected at the back of the HDR1 or V8000 with the STB-C of the TV set. I am pretty sure that can be done with the DVD2 as well.
Which TV have you got Santiago?
Ok, didn't know that, my avantDVD32 is almost 6 years old...
