Has anyone used the Beolab 6000 wall brackets?
its more a slot on the bottom of the bracket. You could drill to the left or right at an angle so it would come out at the side of the stud.
Large48 wrote:
Some B&O shops have them wall mounted, King Street perhaps? I can't remember exactly!
I think that Selfridges in London has them wall-mounted.
OK I went ahead and ordered a pair for my front BL6000s and have another set of mounts for my matching rears.  The mounts look very good and are very secure when screwed in to a stud.  Basically you remove the bottom foot and then replace it with bolts that attach the speaker to the wall mounts.
Here's one problem with the design, however.  The channel underneath for the wires is directly below the mounting holes.  So, if you want to feed the wires in to the wall you have to do it over to the side and just under the bottom of the mount, because otherwise you are going right in to the stud.
Overall it makes the BL6000s look awesome so I am very happy!
Maybe a photo needed?
Some found here before.... I think...
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
joeyboygolf wrote:
Use two round headed lag (?) screws
This is the North American term for coach screw, I believe... 'Lag' here is an old term for a stave (or single vertical element) of a barrel, and a lag screw was originally designed to attach barrel staves to the encompassing metal rings.
The type of screws don't matter.  The fact is that the holes to mount are directly above the speaker channel in the mount.  So, it means you have to have the wire going off to the side.  Not a big deal but not the best design.
Hi, B&O’s warning about fixing into studs is basically to cover their own backs, very similar to what you will get from any manufacturer of TV wall brackets etc. to guard against some ambitious DIY’er trying to fix a 10Kg load into a plasterboard wall with do-it-all nylon plugs they've found at the bottom of their toolbox.
Ideally, you do want to find a wooden stud, but it's unlikely they will be conveniently where you need them to be. If you use the correct fixings, then these will go anywhere on a good-condition plasterboard wall.
Something like this:
link
It’s worth using a fitting tool to get the best possible grip, and DO NOT over tighten once the fitting has gripped – use a hand screwdriver only and not a powertool, otherwise you run the risk of stripping the threads and these are extremely difficult to remove if they go bad.
I think Rawlplug have an equivalent, but I trust Fischer after many years of use in various similar applications. On something this close to the wall you need to be more concerned about shearing forces than weight, there’s also an app you can download from Fischer to calculate what you need if you are really worried.
The fitting tool & fittings themselves are not particularly cheap, but when you are looking to hang £1000's on the wall, it’s not worth cutting corners.
I fitted several Beolab 3500’s, 5000’s and various plasmas into plasterboard walls with these, not to mention heavy mirrors and cabinets, and they’ve never moved in years. After all, they are designed to hold kitchen cabinets up, loaded with who knows what, so a Beolab 6000 is not going to be a problem.
Having said all that, the walls need to be in good, sound condition and fitted correctly. Don’t blame me if it goes wrong!
Cheers,
Mike.
Thanks for the update.  I now have 4 BL6000 mounted, and I chose to do them all on studs.  I would be OK doing BL3s on sheetrock but I would be a bit nervouse with the BL6000s as there is also a lot of torque that they could apply to a wall with their length.
I still think the design is poor as I had to route the cables off to the side, but they still look awesome!
Are these still availble if so any one know the cost?
Yes they are still available...they are around $225 USD a pair I think.
