<image removed>
Hi all!
Thanks for the many responses, particularly Geoff for the relevant technical perspective on doing this.
I actually wrote a reply as soon as I plugged it in and turned it up, but it was somehow lost in the ether, which is probably a good thing because it was an emotional response!! I can't stop listening to music all of a sudden!
My first impressions were shock and disbelief, because of the physical impact I was suddenly accessing! I was expecting it to be messy and over the top.
My setup is aesthetically awful, I know, this is a temporary solution, we just got a kitten so they're in this small room and out of paws reach! I've always been a little underwhelmed with the visceral impact the bl9s have in the lower end at higher volumes, going from bl1s...
Anyway, I'm surprisingly very happy with this setup having the BL2 assisting on the side! I have the bass turned down on the Beosound, from 0 to -2 and the BL2 is on its lower settings (corner and setup 2, - setup 1 was too loud for me). I've been wavering between setup 3 and 2 on the BL2 actually.
I've had a bit of a play around and I've listened (using the B&O Active Listening III CD) with and without the BL2 plugged in, there is a mild difference at lower volumes where the bl2 seems to discretely cover what the bl9s are missing, it's when I turn the music up much louder that the difference is earth-shattering, erring on emotional!
It's a more relentless sound now and is a great improvement when at full blast (well up to VOL 62 anyway) and I'm outside doing gardening... My theory is that the BL9s are working slightly less hard having turned the bass down a little, but the BL2 adds a punchy element to the lower end and covers the notes in between that the BL9 doesn't reproduce as strongly in some tracks.
I strongly recommend you try this yourself if you have a BL2 and BL9s, especially if you're planning a party or turn your system up louder than what would be acceptable in a domestic environment! (my nearest neighbors are over 15kms away)
Summing up, adding the Beolab 2 has essentially added a more visceral (i hope that's the right word) element to listening without taking away from the BL9s, but it's subjective of course, and everyones tastes and setups are different. When i have my way I'll just have Beolab 5s.
Thanks for reading 😕
