Timhanna,
What made you decide to go for that particular TV, over some of the other non B&O TV's, which on the face of it appear to provide the same picture quality if not better. ?
Timhanna,
Hi Akeithj,
I originally was happy to settle with the 32 inch, but the lack of HDMI (tragedy) made me change my mind and go for the 40.
Other TVs are good as well of course. However a b&o tv is a central item for a b&o setup. I have my speakers connected to it and my ouverture as well. Its the hub of the entertainment system and it really goes nicely in my flat (colour wise). Ill send a photo one day. So thats really a major reason why i went with it. Plus it has the basic features that wont change (for my needs) for lcds. I.e. 1080P which is great. 24P, 4x HDMI, DVD Player... For me its as future proof as im going.
If i though about it properly, with my brain instead of my heart, then i think the best option would be to do for an good non LCD TV, or even an AVANT, seriously great stuff. Wait until all this mess with HD settles down, then get one.
The b&o TVs ARE not worth the pricetag, seriously overpriced, since for just under £9K it should have 120Hz and everything included, like DVD-Rec, FreeSat etc etc. Its part of the reason that b&o is loosing loads of money and serves them right.
Myself, i tend to save up and buy one thing and keep it for life. Im hoping that this TV does so.
bikerscotty:
[...]in January I changed the avant for a Loewe Compose 52" and the engineers used my existing powerlink cable and connections to connect the speakers to the surround sound processer in the Loewe and I control everything as I did before, It is really the best of both worlds and I have added a Blu Ray Player to the equation as well, Job was easy, no recabling required and I have a bigger size TV with an excellant picture and freeview, Freesat and a 160Gb Hard drive all built in.
Never been happier
I think you are interesting a lot of people here bikerscotty... (at least myself!!) Can you describe more precisely how everything is connected (if you have some pictures...), because the last time I spoke to my Loewe dealer he says there were no product on the Loewe portfolio other than the Blu ray player that have 5.1 outputs in analogic/variable line signals... So no way to connect the Loewe to 5+1 B&O speakers.
Are your speakers directly connected to the TV or to the Blu ray (so you can only get the B&O sound with DVD/blu rays, not TV...), or to another Loewe sound processor?
And last question : can you play DTS HD Master Audio and other typical blu ray sound formats with your system?
Hi there, sorry been away for a bit, I have a compose 52" on the wall, the Loewe TV's with the AC3 module use the RS232 connection on the back with an adapter labelled for Centre, Front L, Front R, Rear L, Rear R and Subwoofer which you then plug the BAng & Olufsen speakers into. It sounds like your dealer was not the most knowledgable in Loewe, I must admit the store I use and have always used used to be a B&o store and I like the guys there, they are good at "thinking out of the box" and if you get by one of thems dread locks (haha) they are very knowledgeable guys. So yes the speakers are connected directly to the TV I added the Blu ray player later on in a big heavy metal cabinet called a cube i, anything that plays through the TV plays in the surround sound, It does DTS yes, I must admit i notice absolutely no difference in sound, I used to be in the Av market many many years ago and specifically bang & olufsen so I feel I should hear the difference if there is any.
The important thing is I like the system and it suits me great, if you want to contact the store I use then PM me and I can pass on details.
BS
Sound quality on the Sound Projector is lower than with a good set of Beolabs... But it's not the same price...
Another question for you BS : I don't think that there is an on/off signal provided by this cable, so does it work correctly with a low level? In case of stereo listening, does each Beolab switch on? And when you turn off the TV, the Beolabs turn off after 3 minutes? Last question : if while listening to a 5.1 movie, there is no signal on the rear channel for 3 minutes, does the rear Beolabs switch off, making you miss the begining of the next rear effect?
Thanks again for your help! (considering your dealer, I don't think he would be helpful for me as I live in France!)
Re Soundprojector, Why would you want two surround sound options running side by side, I phoned Bryan at my dealer as well and he said plug the soundprojector into digital out and the Bang & Olufsen speakers into the RS232
Regarding low level I have tried this last night and it worked fine I have had no problem with the rear channel dropping out, maybe i listen to films with too many explosions! but all we have connected is the Beolabs and normal TV or films is fine, If you have any questions they are more than happy to answer them and probably give more precise answers than me! They are more interesting in helping than selling you stuff and are very approachable, say you were talking to Scott with the Vmax.
BS
Thanks Bikerscotty,
Do you still use the Beo4 or only the Loewe remote ?
I use the aluminium Assist 1, its the new upgrade that came out which I can control my Sky HD with, we use the Beo4 with the Beosound 1 in our conservatory.
BS
