Harmony software
It is frustrating to see that Bang&Olufsen does not change / enhance it.
New software 3.0 for Hamony, don’t now what’s new..
Is it possible to stream the sound of TV life program from a Beovision Harmony in sync to a NL speaker e.g. Beosound 35?
Similar as it was possible via Masterlink. I would like to listen to my Beosound 35 at the kitchen when e.g. news is running in the living room on a Beovision Harmony.
Audio wrote:
Is it possible to stream the sound of TV life program from a Beovision Harmony in sync to a NL speaker e.g. Beosound 35? Similar as it was possible via Masterlink. I would like to listen to my Beosound 35 at the kitchen when e.g. news is running in the living room on a Beovision Harmony.
Absolutely
When I stream the sound of a live tv program from my Eclipse to my Beoplay M5 over NL, the sound on the M5 is delayed and thus out of sync with the Eclipse.
I assume, that this will be the same on the Harmony ...
Best regards
Dyssegaard
There’s an option on the BV11 to adjust the network delay which can be used to fix that. I would hope the new LG based sets have something similar.
I just tested it. Similar situation here, when I connect my Beosound 1 or Beoplay M3 to my Beovision Harmony I have a heavy delay listening to TV (no problem listening to Radio at the Harmony). But I still use the standard sync settings of 50 / 1000 msec.
@andy_js: What network delay settings you are using, to have it in sync?
New 3.1 software out
I assume, that this will be the same on the Harmony ... Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K, Bedroom: Beovision 11-40 , AppleTV 4 . Home office: Beolit 12, Kitchen: Beoplay M5 . Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
You adjust the audio delay in the app under M5 and then it will be in sync
I had that when i got the A9 years ago and as soon as I changed it, never an issue anymore.
I have found this useful document at B&O Customer support:
https://bogo.custhelp.com/ci/fattach/get/1304261/0/filename/Multiroom+-+october+2017+-+PDF+handout.pdf
At page 10 it is stated for Eclipse, that sound is delayed in link rooms for all video sources.
At page 2 it is stated for BV11 and Beoplay V1, that sound will be in sync in link rooms for all video sources.
Both statements reflects my observations with my Beoplay M5 connected to Eclipse or BV11 via NL.
However, since the document is dated October 2017, there is no information regarding the Harmony.
Best regards
Dyssegaard
