It is frustrating to see that Bang&Olufsen does not change / enhance it.
Harmony software
New software 3.0 for Hamony, don’t now what’s new..
Is it possible to stream the sound of TV life program from a Beovision Harmony in sync to a NL speaker e.g. Beosound 35?
Similar as it was possible via Masterlink. I would like to listen to my Beosound 35 at the kitchen when e.g. news is running in the living room on a Beovision Harmony.
AbsolutelyIs it possible to stream the sound of TV life program from a Beovision Harmony in sync to a NL speaker e.g. Beosound 35? Similar as it was possible via Masterlink. I would like to listen to my Beosound 35 at the kitchen when e.g. news is running in the living room on a Beovision Harmony.
When I stream the sound of a live tv program from my Eclipse to my Beoplay M5 over NL, the sound on the M5 is delayed and thus out of sync with the Eclipse.I assume, that this will be the same on the Harmony ...Is it possible to stream the sound of TV life program from a Beovision Harmony in sync to a NL speaker e.g. Beosound 35? Similar as it was possible via Masterlink. I would like to listen to my Beosound 35 at the kitchen when e.g. news is running in the living room on a Beovision Harmony.
Dyssegaard
adjust the network delay
I just tested it. Similar situation here, when I connect my Beosound 1 or Beoplay M3 to my Beovision Harmony I have a heavy delay listening to TV (no problem listening to Radio at the Harmony). But I still use the standard sync settings of 50 / 1000 msec.
@andy_js: What network delay settings you are using, to have it in sync?
New 3.1 software out
You adjust the audio delay in the app under M5 and then it will be in syncI had that when i got the A9 years ago and as soon as I changed it, never an issue anymore.When I stream the sound of a live tv program from my Eclipse to my Beoplay M5 over NL, the sound on the M5 is delayed and thus out of sync with the Eclipse. I assume, that this will be the same on the Harmony ... Best regards - Dyssegaard Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K, Bedroom: Beovision 11-40 , AppleTV 4 . Home office: Beolit 12, Kitchen: Beoplay M5 . Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
Dyssegaard
