Harmony Screen
Yes as the soundcenter is the same, but you’ll have to buy the new fabric/wood panels of the associated size.
I did the switch from 65" to 77", you also need the mounting plate for the back of the LG and they are different from screen to screen.
The swap itself is quite easy, only a couple of screws and the cables. You can easy delete/reset the B&O software and sell the LG.
As the larger speaker cover did not arrive in time I had the 65" cover with the 77"...looks odd...thought in the first place could life with it, but no, I could not. So also consider swapping them as well.
Hope B&O will come up with the cover for the 83" sizes than I will upgrade again.
Thanks for all of the replies.
I think when I do swap from Eclipse to Harmony I would start with 65 or 77 and the fact with some cost they scan be swapped with some speaker covers etc it means it is future proof for now.
