Harmony Issues
Richtw2 wrote:
Another problem - My Harmony TV when turned on opens but there is no sound from the speakers i.e. the sound centre has disconnected? It is intermittent and can be restored by power cycling the whole system off and on?
This is also connected to my previous question about the BL28 speakers not reconnecting over WiSA.
It really 'feels' like there is either a software conflict or an actual hardware problem?
Has anyone with a Harmony had a similar issue?
Yes. And I found the solution.
Turn off Quick Start Plus
Is the Quick start plus in the B&O app side or on the LG side of the menus?  maybe there is hope :)
Lg side menu thanks
My issue was the same as yours.
I have a Harmony and an external Foxtel STB (same as Sky Q) and also an XBox plugged in to the HDMI of the Sound Centre.
What was happening and it might have been after an update, but it just randomly started where the Sound Centre and the LG is like they are disconnected "handshake issue".
Issue:
  • Press TV (Foxtel)
  • TV would raise
  • Harmony speakers would open
  • No Sound
  • No Volume On Screen Display
  • No List functions on the BR1 so you wouldn’t be able to use the Stand / Speaker options
The work around was for me (just power cycling the LG screen would cause them to be connected again after start) :
  • Start the Harmony up (no sound etc)
  • Then after 5 minutes or so (don’t go too early), You would have to get the LG remote and press the power button once
  • It would then cycle the TV off (with the harmony speakers on) , and then cycle it on (it takes about 30 seconds)
  • If i didn’t wait 5 mins what would happen is you have to press the power off and hold down BR1 power for a total NL shutdown
  • TV would restart with the speakers still open
  • Volume On Screen Display would come up
  • List functions restored; and
  • Splash screen saying “wired network is connected”
I would complete the work around and then over night when it's like everything goes in to a deep sleep, i would have to repeat it on the first start up of the day
B&O service came out and did a software update but that didn’t do anything
After that B&O service said they would like to come and replace the main board, which I’m hesitant to do at this stage.  It's brand new basically!
So i started doing a few tests in between this:
  • Changed CEC off my Foxtel Box
  • Quick Start Plus Off (which was a tip from Paul the Tech Giant on YouTube) on LG C1 with Sky Q boxes
  • Spamming the LG remote mute button and doing an AV reset
After testing these scenarios and then leaving over night and testing, it come to that if you turn off the Quick Start Plus  to off on the LG menu in the LG (not the B&O app nor the Harmony Sound Centre), I don't seem to have the same issue overnight which is what i did before.
I have an LG G1 so it's under the General > Devices > TV Management
I’m monitoring it and will confirm with the service if it in fact works or it might go suddenly again.  Other scenarios i will test because it wasn't also happening with the Foxtel box is what happens when i test say starting YouTube from Standby.
You can also reach out to me via private message and I’m happy to hop on a call with you if you want.
Your other issue, there is a setting in the B&O app on the TV whereby it will keep the power to WISA speakers, so also check that setting.
Cheers,
Michael.
Thanks Michael... have unchecked the Quick Start Plus last night... will report back!
The Powered WiSA box on the B&O TV app is checked.  At this stage I think the BL28 speaker disconnect issue is related to the Harmony, its almost as though there is a software crash which is causing the Harmony Sound Centre to not connect and then the BL28 speakers to not connect (which of course they cant if the Harmony is not connected)...
Bit of a struggle this one!
Ah yep.
I get you now. Your BL28 issue may not be because of the BL28’s but just like my BL18, BL19 and the BL3s would not connect until “wired network is connected” which happens now that I have Quick Start Plus disengaged.
Together, we achieve more. :-)
