Hi All,
I have a BV3-32 with a motorized stand (motor platform and cabinet), and I enjoy the possibility to turn the TV set to my perfect viewing position just as much as to impress visitors who never seen a B&O TV in action before. 🙂
However, recently the motor stand has begun giving some friction noise when working that gave me the impression that the machinery needed to be oiled..
Lazy as I am, I sprayed some "universal oil and anti corrosion" stuff in the little opening between the bottom and the top of the heavy platforms. Convinced this was the way to go, since I earlier in the day fixed the central locking in my car with that spray, I thought this must be the best invention since sliced bread..💡
And, it actually took off some of the friction sound from the stand at first, so I gave it some more. It worked fine all saturday.
When I turned the TV on Sunday morning, it moved an inch and then stopped. Dead. Obviously the spray had worked itself into the electronics somehow and killed it. [:'(]
Finally, after getting help from my teenage son to lift the heavy TV and take off the motorstand, I disassembled it and sprayed another "Universal Electronic Cleaner"-spray on the electrics..and Voila! ..it started working again!..
So, now to my question: what kind of grease do you recommend for the motorstand to move silent and smooth?
(and yes..I will keep away from "Universal Wonder Spray's")
/Peter
