Grainy picture on beovision 7 - i am desperate
I have these error codes also at my BV9. Saw them also this at a friends place with his 7-40 mk3. I think these errors (22-2D) has to do with teletext or something. Nothing with the grainy picture, that's for sure.
And for the flickering and/or blinking, I would suspect the cables either. What happens if you setup the Oppo for 720P or 1080i?
sorry to erect an old thread! I have the same issue did you get to the bottom of it??
same error codes aswell and my screen look like interference affecting the picture
thanks Nick
HiI made recently tests with a philips led tv and a bv 7 40 mk6 connected to a panasonic bdt 700.The philips had these blinking issue until I remove the 100 hz function.I didn't notice any issue with the mk6 unless I was using too much noise reduction and clearness correction.I had also a big issue with an hdmi cable, I finally dump it.I use actually contiental edison hdmi flat cables with hdelite hdmi splitter cable because of the length of my hdmi cables : no problem.It could also come from the bad quality of the bluray.Like the bl5 with bad source, the mk6 won't give you the best results with bad sources.A grainy image is not really surprising with some bluray whatever the tv you are using. 300"is a really grainy br for example.I suspect also interferences coming from the main cables or masterlink connections.If the hdmi cable is not enough blinded, it could cause some issue.sorry to erect an old thread! I have the same issue did you get to the bottom of it??same error codes aswell and my screen look like interference affecting the picturethanks Nick
Hello Nick,
Long Story for me, but with happy ending. After 6 months and 4 repairs at home, my dealer send the beovision back to Struer, and they completely change the screen and not only the CPU and picture mother board. After that, since 3 months now, not a single flickering of the screen.
I change nothing else in my installation, same hdmi cables, same connections, same dvd player and setopbox, It was a non identifiable problem, but they have done their job.
Hope it stay like this for the next 10 years.
best regards
Eric
Hello Nick,
best regards
Eric
thanks for the replies, fingers crossed mine gets sorted the dealer is picking it up tomorrow
