Ghosts turning on my BO3000?
For the past month or so my BO3000 has started to switch it self on automatically. From stand-by mode or from playing a CD, Radio channel 8 some times switches on. This happens once or twice a wee and none of my neighbours are using B&O remote controls or similar…
Any clue what this can be about?
// Martin
Hello murbeck
If I close down my computer whilst N.Radio or N.Music is active it can leave my BS3000 switched on (though not playing music).
Just a thought, clearly doesn't apply if you don't use Beoport.
Gordon
I wonder if it could be a fault in your remote rather than the 3000. Maybe a problem with the key contacts. If it was that, I would expect to see Radio displayed on the Beo4 though.
Check if you made a timer by a mistake, if the radio is connect to a TV! Look in the timer play menu on the TV then....
