Ghosting on BV 7-55 in 3D
Sorry to disagree Martinw, , but after software update by technician, the same problem did remain. I agree with BEOCET who said that the image becomes better after one hour (I would say after half an hour) but it's still not perfect.
Still have to do a software update of the BR player (download is interrupted each time i have tried with the mesage "error during download)" but problem occurs also on VOD, so few hope that update succeeds to solve this issue.
strange that so few poeple complain about that
Sorry to hear the software hasn't fixed your issue - we have 2 Mk2 BV7-55's on display here and many with customers - the 3D is great with no ghosting - but as I said before that is since the software was updated about a year ago.
You may have faulty glasses that are not syncing properly with the TV.
Don't settle for poor ghosting though - that is not a feature of the BV7-55 Mk2!
I have since beginning noticed the ghosting effect in 3D. When the Tv has been on about one hour, then you reach the maximum performance of the screen and therfore minimum of ghosting, but it is still there!
The BV 7-55 3D suffer also from another problem: CLOUDING EFFECT in 3D-mode. I have had my TV changed 4 times because of this, but still a lot of clouding effect in 3D-mode. In 2D-mode the picture is perfect but 3D is not so very good for the price-tag of the TV.
Updated the BV 7-55 3D to the latest firmware and after having watched 2 3D movies, I must admit that the quality improved and that the mentioned side-effects disappeared or were barely noticeable.
Hi Gabriel,
can you tell me the version (build) of the actual software of your BV 7-55 3D (it's shown in service menue)?
Regards
Räuber
Sure. It's SW13.12a for AP and SW23.00a for IOP.
Thank you very much. That's build 1112 (first line), correct?
Well it's not indicated. Update has been performed 3 weeks ago
Hi Gabriel,
if you press RED - GO instead of 0 0 GO you call the customer service menue and there the BUILD is shown under SW VER.
/Räuber
I'm sorry, but nothing shows up when pressing red+go instead of 0 0 go.
