Thanks, but I am not an expert!
B&O have issued an SW update for the BeoMedia to avoid burn-in on their plasma (PDP) series (current and past): Set the display time-out to three minutes and the darken level to 200 in the BeoMedia settings as described below:
<LIST> /PC/ <GO> <R> <9>
SETTINGS:
- DISPLAY TIME OUT: 3 MIN
- DARKEN LEVEL: 200
If you follow this recommendation, then B&O's tech dept have found that your expensive plasma display is safe when used with their BeoMedia 1. Not that the above settings are done in the BeoMedia setup menu (not the tv's) as indicated <GO> <R> <9>
Roger
