Full HD Beovision 4-50
Thanks, but I am not an expert!
B&O have issued an SW update for the BeoMedia to avoid burn-in on their plasma (PDP) series (current and past): Set the display time-out to three minutes and the darken level to 200 in the BeoMedia settings as described below:
<LIST> /PC/ <GO> <R> <9>
SETTINGS:
- DISPLAY TIME OUT:  3 MIN
- DARKEN LEVEL:  200
If you follow this recommendation, then B&O's tech dept have found that your expensive plasma display is safe when used with their BeoMedia 1. Not that the above settings are done in the BeoMedia setup menu (not the tv's) as indicated <GO> <R> <9>
Roger
Thanks Roger!!!
great help... I really appreciate... regards from Italy!
You can also use P.MUTE on the beo4 to switch off the plasma if you like. (you may need to add P.MUTE to your list menu on Beo4)
Regards
Peter
havent figured out how to post pictures....have one of the complete description of my BV 4-50 on the back.
But its type: 9021
Item: 1818729
S/N: 19610844
I assume that this is G9, but can anyone ID as to which extend of HD this is ??
thanks
John
PS: am I happy with it: YES !!! - would just be nice to know.....
Is the type no of your BeoSystem 2: 941x?
Roger
hi Roger,
I assume that was a question for me. I have a Beosystem 3, not 2.
have to see the Type number later - can't get to it now. But is that relevant to the monitor specs ?
 I am aware of course that the Beosystem has to be able to handle HD ...but my BS 3 is.
rgds
John
Sorry, John - my mistake. The following type numbers contain the D9 panel: 8954, 8955, 9020 - 9028.
Roger
Thanks Roger, so would you be able to varify that with a type # 9021,  that this is a D9 / "normal HD" monitor. Not "full HD"...?
rgds
John
I have D9 in my Full HD BV9
so there is 2 types of D9?
