Full HD Beovision 4-50
The new full HD Panasonic panels and tv 's with the contrast ration 10000:1 are shown now at the IFA in Berlin.
Also available now, so If you say next spring, maybe B&O waits for next spring to use them ?
335f, the current Panasonic line up for the comercial panels has g10 panels for HD-Ready and the g9 panels for Full-HD.
http://www.panasonic.co.uk/plasma-displays/index.htm
The consumer line up has all g10, regardless Full-HD or HD-ready, in Japan, new consumer models were anounced just a couple of days ago (model name xxx750) including 24p for the full HD range. Not sure if Panasonic will show these new models at the IFA fair, however, I can tell you on Saturday....
Karsten
Dear all,
 thanks for your input. - I agree, would be amazing if they use the latest panel. I wonder if I take one from the shop NOT Full hd but with an discount as im am not sure wether this will be a big benefit on a 50" screen....
 Let us know how IFA was.
jp
Dear All,
I would like to ask you a few questions:
1) I have just ordered a few days ago a BeoVision 9 which is supposed to be Full HD (1080p). How can I verify that is correct when I receive the TV? I'm getting a bit confused with all these different panels and specs...
2) Furthermore, I requested this to come with the BeoMedia installed, but I'm a bit concerened about possible BURN-IN if I use that BeoMedia a lot for images or MP3... should that be a legitimate concern?
3) I will have paired up with a Playstation 3 too... can gaming be in issue with regards to BURN-IN?
4) Do B&O tvs need to be calibrated? or is something I have to deal with myself?
Your advise would be very much appreciated... cheers!
Mass
1. for 2 weeks ago I bought the last one in stock and it´s Full HD 1080P, so no problem there
2.burnin problem seems to NOT be a problem anymore
3. see question 2
4. dont think so, only if you connect a projector then maybe you will calib. that
good luck
Hi Roger!
thanks for your help...
Since you really seem to be an expert can you tell me a little bit more about BEOMEDIA and BURN IN? I am still in time to ask my dealer to get me the BV 9 without the BeoMedia if that is better... what would you recommend?
I like the idea of seeing my pictures on the BV9 and playing there my MP3 files, but of course don't want to get the screen ruined becasue of that...
Thanks again for your preciousa advises!!! ciao!
