Form 1 parts
OK, my foam parts of my Form 1's finally rotted. I successfully removed all 4 pieces. Does anyone know where I might find replacements if they are still available?
On that note, I discovered that the strap itself is covered in flocking material, which also rots. I went to a materials supplier here and replaced the strap with genuine leather. It looks good. All I need are the foam pieces. I'll upload photos one complete!
The foam pads are still available from your B&O dealer.
I think the Headphones are still available also.
Not sure that you are correct here Brett! I think these were unavailable from around two years ago. You may be thinking of Form 2's.
Lee at Lifestyle AV did have a small stock of Form 1 replacement pad kits but even that may be old info.
I am of course quite willing to be corrected so check with your dealer.
I have a set of 4, new and boxed, if you cannot purchase any from your dealer.
E-mail me if you require them.
MERCATS
Thanks for the info. I will call my local dealer to find out about its availability.
However, while we're on this, does anyone know of anything else that can be used in place of the foam parts? After all, new foam will only end up the way of the old foam.
FORM 1 FOAM PIECES
Craig🙂
I bought the Form 1 replacement pad kit from LifeStyle AV. Perhaps a bit expensive but certainly was worth it. The old pads must be completely scratched off - I used my thumb nail. The kit has all the pads (two big ones and the two smaller ones) and they have a tape to attach them to the headphones. If the old rot is taken off well the new ones should stick there well. Mine has been now in use with the new pads for some weeks and no trouble at all. And now the Form 1's really fit my ears better than before.
 EDIT: I'd like to have some photos of the replacement strap. The one in my Form 1's is a bit worn and I'd like to see how well the replacement fits.
I bought 3 pairs of form 1 pads from the vegas dealer only 6 months ago.
I then got home and was told by that they were still available from uk dealers.
I may have been wrong about the headphones still being available. But i'm sure i'm right about the pads!!
Listen to jbg - Dad's know best😕
