For those owning BL 17,18,19,20 and a TR1: New software available since Jan 15 2018
If you have the Transmitter 1 go to https://www.bang-olufsen.com/en/product-support/accessories/beolab-transmitter-1
The webpage has instructions and the software update.
I have the Transmitter 1 and was able to update all my Receiver 1's via the instructions and the software update.
I have a beovision avant ng
Sounds like itโ€™s almost worth buying a transmitter 1 for just doing updates ๐Ÿ˜ฎ
To update your speakers you will need either a Transmitter 1 or an installer with the service tool to plug in directly to your speaker for the update.
That sucks...
I have got two BL 18, one BL 19 and a BeoSound Moment. As far as I understand it is only possible to update via the Transmitter 1 or the Service Tool. Or is there however an option to do it via the BeoSound Moment for the Speakers? ๐Ÿ™‚
Have great day everybody!!!!
The above is correct.
When I first connected my 17s to my moment (? March last year) the Moment interface notified me that it was updating their software. So, it seems there is some mechanism for connected products to keep the speakers up to date.
I have been told by a B&O technician that the TV (they are now connected to a BV14) updates their firmware but not the entire update package and that the only way to ensure you have the entire update is as already mentioned here.
That is, via technician with service tool or Transmitter 1 loaded with appropriate software.
Would be interested if anyone had further info on what the TV or Moment can update in the speakers...
Cheers
Scott
Cheers
Scott
Because the B&O representatives are watching BeoWorld, why do they not appear for a question like these? Maybe the sheep are in their own stalls. If your dealer is 100s of kilometers away does this mean you may not get new software updates? B&O are importantly an online company now like so many others so they should be able to provide an online solution.
Register to access the forums, reference material, and exclusive member benefits โ€” including our monthly prize draw.
