Hi there. Does anyone know a way of getting FM on the Beosound 8 apart from attaching an Ipod Nano?
FM radio on Beosound 8
Connected via Cinch/RCA-Phono cable to the Line In of your BSd8, this little box will do the job ...
If you have iTunes you can stream wirelessly your radios directly to the BS8 with an Airport Express and a RCA 3.5mm/Mini Jack plugged in both the BS8 and the Airport Express.
That's pretty simple, and works perfectly at minimum cost (Airport Express 89€ + RCA/Mini Jack 5€)
If you have an iPhone/iPad you will do the same directly from the Apple "Remote" app that let's you stream wirelessly music/radios to the BS8 (with Airport Express connected to the BS8 of course)
Hope this helps.
Oups! You're right Räuber :) I should have read better the question...
I was so happy to help, maybe next time lol
Cheers
