Flash your B&O - new thread!
When you mention the installed B and O app, is that in the sound center or the LG? Did you have to install/add the app?
Yes. I’ve had mine for ten years. Use it most days as an alarm clock. It’s still looks and feels great.Finally got my hands on a BeoTime. It really is such a beautiful piece, something every B&O addict should own!!
I love mine also. Wish I had bought two so I would have a spare.Yes. I’ve had mine for ten years. Use it most days as an alarm clock. It’s still looks and feels great.
I do like the way you have used chunky cable covers and, rather than trying to hide them, made a feature by draping the excess around the speaker base. Look very good indeed.My new B&O Unicorn setup: Eclipse Soundcentre 55" with LG 77" C9 with Bang & olufsen App works perfect
Thank you, In the beginning I didn't know if the placement of the speaker was wide enough, therefore the longer cables. But I always you the more chunky cable covers to get a more robust feeling!
The Bang Olufsen App is available in the LG Content Store for newer LG models, not sure if even B9 or E9 can install the app. But I have verified that 55", 65" & 77" C9 can download and install the app.
Can you tell me what diameter or what make they are? I’ve just wired my BL18s and BL19 (as described on another thread) and those cable covers may well be of interest.Thank you, In the beginning I didn't know if the placement of the speaker was wide enough, therefore the longer cables. But I always you the more chunky cable covers to get a more robust feeling!
Desperate times need desperate measures. Probably the only rugby for 3,000 miles, and the Beoplay A2 active at least makes up for the tiny screen
Login to view image
Yes but at least you are watching. Went to the England Ireland match a couple of weeks ago and I’m gutted to be watching this game on 55 inches.Desperate times need desperate measures. Probably the only rugby for 3,000 miles, and the Beoplay A2 active at least makes up for the tiny screen
DIY Beoplay A3 😁
