Flash your B&O - new thread!
Looks great, Hiort. 😁
//EA
Just moved into a new loft.
Setup:
Beolab 18
Beolab 3 (Rear speakers not shown)
Cool looking industrial space with that cement wall!... I did think you had Pop-Tarts lined up on your coffee table, though πŸ˜•
I know you've probably answered this before, but what brand sub and center is that?
Thank you. Pop tarts are slate coasters painted Rose Gold actually ;)
Here is the Centre:
http://www.bowers-wilkins.com/Speakers/Home_Audio/CM_Series/CM-Centre-S2.html
Sub:
http://www.bowers-wilkins.com/Speakers/Home_Audio/Subwoofers/ASW10CM-S2.html
hello,
Thanks for the advice, I'm sure the BL11 does sound fantastic. Geoff Martin has some good answers on his blog about the effect of a sub on a 2-way speaker's performances in the mid-range. I'm looking forward to experiencing this.
I was actually more considering buying a BL19 as it is wireless. Also, I'm a big fan of its design.
Does anyone have an experience using the BL18+BL19 combo ? πŸ™‚
Sorry, that was addressed to Miho-
keynesparis6 wrote:
hello,
One thing to consider when considering a BL19 is that unless you use the wireless transmitter to talk to both the BL19 and BL18, there will not be a high pass filter/crossover for the BL18. The internal Bl19 crossover is only a low pass one for the sub, the BL18 would still be reproducing all the bass sent to it, removing the benefits of taking the bass out of the BL18s.
Jeff- thanks for your reply. I also have a WISA-enabled BV11 as my setup's central brain. I assume the BV11 will serve as the wireless transmitter you're taking about ?
Keynes6-
Ah, yes, the BV11 should have all the smarts to route signals to each speaker appropriately, wired or wirelessly. Part of the B&O video/audio engine in it is the ability to recognize speakers and allocate frequencies to each as far as I understand it.
Initial 'preview' picture (I guess you can consider that a 'flash'). Full room pictures on the way (once I complete the setup), but the sun shining through the blinds just looked so sweet to not take the photo.
