x16szr wrote:
Hello Razlaw, looks very fine on the wall. Which was are the two Beosounds connected to your Beolabs?! Do you use any "Converter" or are they parallel to the two PL sockets to every Beolab? Greets.
My apologies again. Rereading your question I realized I may have misunderstood what you were asking and thus not answered your question. I do not have two Beosounds connected but it may appear that I do with both the Beosound 5 and the Essence remote. The Beosound 5 is connected to a Beovision 10 and speakers in the same room as the Beosound 5. It is also connected to a Beovision 7 and speakers in another room. As I want to use the play timer in the Beovision 7, and the Beovision 10 does not have a play timer, the Beovision 7 is set as the video master.
Thus, if I turn on the Beosound 5 by spinning the wheels on it, instead of using a Beo 4, it turns the speakers on in the other room that are connected to the Beovision 7. Additionally the volume control on the Beosound 5 adjusts the volume in the other room.
I have the Essence remote set up such that a quick press turns on Net Radio and a long Press turns on Net Music, through the speakers in the same room as the Beosound 5. Additionally the volume control of the Essence remote controls the speakers in the same room as the Beosound 5 and Essence remote.
