Flash your B&O - new thread!
Thanks for your replies. You got me hooked, this sounds really cool. This would make the perfect box to hide away stuff.
Will the HDR2 or BM5000 be fully empty or are there elements that cannot be removed? WOuld really love to have a clean metal box that I can use to hude away cables.
I removed all the internals on my beocord 5500, then used a metal grinder to make it flush inside. Then I mounted the ice-modules.
the_o_master wrote:
And how is your setup connected to the BV 7-32? Do you use this CX-100 as a central speaker? How did you connect the Cona in the setup (is it the COna in the right corner)?
The  BV7-32 is connected to the beomaster via ML-T1611-Datalink-aux/tape2 connection. Works perfect throughout the house with MCL system. The center powerlink from the BV is connected to a beolink passive, which is hidden in the big closet next to the mc30. The cona is connected to the bl passive, and the CX100 are actually 2 Cx50, left and right center, connected to the outputs of the Cona. I did not really like any of the Bv7 center labs. I tried to connect the cona to the sub powerlink, but that only works with 5.1 configuration, and I coul not fit more speakers in the room. The beomaster is connected to RL60.2 and RL35 speakers. So the CX and Cona are only for the BV.
I did not have the necessary tools
White Beogram 6000 fitted with an Axel MMC20CL nestled among other items and sitting on a Merrow Associates table.
Made for one another !
Enjoying my new A3 from the balcony of my vacation condo. Excellent sound from such a small device.
Dom
As I see your iPad doesn't have a jailbreak. I hope you have a key to get out.
SCNR
By the way: that's a good holiday device.
my beolab 8000 system is now being stored in the basement.
Instead of i had this system.
Henrik
