Flash your B&O - new thread!
Very nice setup you've got๐Ÿ˜•
Thanks guys
Nice to finally see your Avant Michael!
Who will be the first to flash a Moment? ๐Ÿ™‚
Thanks riven.
So guys if I were to get an S8 where do you suggest I place the front 2 satellites if I decide to use it as fronts
I think they should be in the same height as your center channel. But it would look a little bit weird.
I have never noticed any difference in sound when I have had the 3 front speakers in different height.
Considering the layout of your room, I don't think it will make too much difference. (You have the tv in a corner, right?)
Old and new working together!  One of the PM's Powerlink outputs is actually used to trigger a B&O Remote Switch which then switches on the BM900.  Hence when you start streaming music the whole 'system' turns on automatically!  (Sorry about the wires - it's a temporary set up!)
๐Ÿ˜‚ Lovely!
BeoFantast Denmark@   Nice, and how did you fix it- can't zoom in the pictures?
I'm so sorry I respond a little bit late. This is an enlarged photo. You can see what kind of materials I have used to fix the Beoremote One into the old BEO 4 holder. I hope it gives you inspiration to do the same. Success.
Changed my beloved bv 5 hd for another 7-40 mk6,and moved things around.I found myself using my bv 7 in my music room more than the bv5,so had to buy another as they are a bargain now and still have one of the best pictures,I looked at bv11 but I thought the bv7-40 mark 6 had a better picture.I got it old stock new in box
Register to access the forums, reference material, and exclusive member benefits โ€” including our monthly prize draw.
