Login to view image
Login to view image
Login to view image
Here is my BC2300 DAB, rescued from a barn, covered in spiderweb and dust. The CD Player wasn't working otherwise it was just in need of a good cleaning.
Changed the laser and then it was working again :)
Unfortunatelly the DAB box is missing, but the Apple Newton was present, it needed cleaning in the battery box and new batteries, but then it also worked again...
It should be able to work with a normal Beolink 1000 remote, but I cannot get it working.. it is responding to the Option programming by blinking the red light, so the IR is working. Talked with the guy who actually build the BC2300 DAB back in the days, but he cannot remember which option it should be in, all he remembers is "that something strange was decided" :)
/Weebyx
