a bit dark - taken in December
Flash your B&O!
its all changed a bit now with the addition of a B11. I am very happy with the BL11.
So.. here's my little collection. The BL11 is feeling right at home :-)
AH! Bv3 on BV5 stand looks magnificent! However i can see from here the TV is too heavy for it :( bummer i thought of doing this, but the TV will destroy the cabinet over time.
All looks great mr! ...for now anyway
@Dave: indeed.. BUT :-) My dealer was able to order an additional socket. Should arrive this week. Will be placed in the middle of the cabinet.
The cabinet itself is future proof :-) It seems that a BV8-40 is as wide as the cabinet...
Oooh! :D I didn't know that was possible, what is it? a piece of wood that goes underneath the stand?
Hi Karel,
Your setup is really NICE, the BL11 is very stylish.
BTW, BL8000 and Ouverture are Old school but old school rules ๐ I have those ones and I just LOVE them.
Meantime, how do you do to keep the BL8000's floor stand cleaned. Mine are getting white (incrusted dust). I have a lot of difficulties to get rid of it ?
Thanks for your help regarding this issue.
Cheers,
Guy
@David: it's a (3rd) alu foot. Just like the other. Here's what the orderlist contains:
1 Plastic foot floor stand BeoVision 5
1 Screw 6x45mm
1 Nut
1 Foot
Total: 36โฌ; typical B&O :-)
@Guy: I just clean them once a week... Takes 30sec/speaker.. Just a wet cloth. That's it... They look as if the you come out of the packaging... Even after 9 years
Thanks Karel,
In fact I am using this method* each month (๐ฎ) but may be shall I use an anti-calcareous solution in order to prevent any incrusted sediments on my BL8000 floor stands...
* (wet cloth using plain water)
Cheers,
Guy
I believe the calcium deposits in tap water, which you in central / southern Europe usually have plenty of, could stain the feet. Perhaps try distilled water (probably available cheapest/easiest at speed shops for topping up car batteries) and see if it makes a difference?
Add a little bit of nice smelling dish washing liquid, and start selling it on eBay at 59 โฌ / 200 ml as "Bang & Olufsen Cleaning Solution" ๐ ๐
Register to access the forums, reference material, and exclusive member benefits โ including our monthly prize draw.
