Flash your B&O!
Hi Acanthus,
Very nice and neat set up you have in your living room.
BTW, what is the brand of your coffee table?  It's very stylish.
Thanks for your reply.
Cheers,
Guy
Ville Laustela wrote:
I suppose it's only for the symmetry, the speaker elements being furthest away from each other. In my setup the speakers are anyway just less than a meter away from each other so it doesn't really make that much difference. Also as I don't sit exactly at the center of the speakers and have to adjust balance it's really no problem.
And yes, only Beoworlders will notice! 😎
One of the speakers being the wrong way up (or, actually, the wrong side right!) will attract more attention than the "BANG & OLUFSEN" text being at the top, upside down. Nobody's going to read that anyway.
If you're really picky, you can always swap out the bezel with the bezel from a right-hand side BV3000/BL3000 speaker. There's probably some dead ones around somewhere, so any bit's worth saving from the bin. Especially when it's really shiny, polished stainless! 😐
Judith wrote:
The Beo4 is compatable with the Lutron Grafik Eye, which can be seen between the ladder rungs to the left of the image. The bespoke Saxum ladder is a second attempt to create a lighter ladder and the rungs were replaced and color matched with the blue anodised BeoCenter 6-23 and BeoCom2.
Wow, that was really nice. Lots of blue details! Lovely!
Good to know I'm not alone...
You're space cramped with B&O is very similar to most of ours on here 😁
I'm an automotive audio and acoustic engineer. I design loudspeakers and full sound systems for new automobiles. I also dabble with studio, consumer and pro audio projects from time to time.
Hi Guy,
The coffee table is designed by Paolo Piva for B&B Italy in 1980.
The name of the table is Alanda.
It is not in the production anymore but can be purchased in design auctions.
Regards
Thanks a lot Acanthus,
Your set up and home interior are really GREAT. You have some very good taste, I assure you πŸ™‚.
Cheers,
Guy
Some more B&O πŸ™‚
And one more..
and finally...
