I've got a Sony CDX-A55 inbound that I bought for $30 off eBay which has the same pinout at the A20 - a slightly newer configuration to the original setup. I'd like to definitively know how easy it would be to add a 10-disc CD changer to an 80's - 90's Beosystem. Controllers tend to run $60 or so on eBay, so for under $120, you can add a 10-disc changer to your pizza box system for parties.
Login to view image
Clearly it would not have the panache of a 9000, but it would retain most of the function. On that note, I can report that the system works just fine on a Beomaster 5500 Tape or Tape 2 input with fully functional control via a Beo4 or MCP 5500, as I had expected. I have not attempted it yet, but I'd expect it to work with a 5000/MCP5000 as well, as the Datalink '80 commands required to make it respond should be identical.
The Sony packaging is basically a metal endo-skeleton surrounded by a molded-plastic shell, with large rubber suspension bushings to deal with rough roads - something unnecessary when installed in the home. Unfortunate that B&O didn't really bother to repackage everything in something a bit more B&O-ish. There's absolutely no reason why the system & controller together could not fit in a form factor similar to the pizza boxes (it would admittedly need to be slightly taller) with a metal sliding door to cover the carousel - even the eject button in the usual left corner location would be compatible, and require nothing more than a wire extension to function.
Add a switch to choose between Aux and Tape 2 communication - a trivial addition for a competent programmer, and the system would have been quite versatile. Shoulda coulda woulda.
