Firestick TV and Beovision 10
Struggling to get FirestickTV to work with my Beovision 10-40. Am using HDMI port and  Setup/Connections menu. Tried connecting as DVD, PC, DTV but not getting anywhere. Nothing comes up on the screen. Help appreciated. Alan
I use mine with a BeoVision 10 as V.MEM.
I can look up menu entries this week-end.
But using the manual you should be able to do it...
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
So pressing V.MEM brings up the HDMI port B.
Ralf
I take it you need to use the fire stick remote to control the fire stick? Does it turn on when you select that option?
Thanks for the replies. I've now got FirestickTV working fine and sharing the HDMI port with my Macmini via an HDMI expander.
Yes, I need to use the little AFTV remote, no IRm it is bluetooth, AFAIK.
Ralf
