I came up with the solution of connecting an IR eye to an NL/ML Converter in the bedroom to forward CONTROL commands to my BLI. I use a Global Cache IP2IR IR transmitter to send the macro commands from the BLI to the Kaleidescape player. It works brilliantly! My ONLY problem is getting the center Beoremote One button (the one between the color and up, down, left, right buttons) to send an ENTER command to the Kaleidescape.
I can't seem to find the right command for the Beoremote One center button. Using a macro with the trigger of
"Control Action=Press & Command = GO-PLAY" triggers the macro using the "play" button of the Beoremote One. However, it doesn't work with the center button.
"Control Action=Press & Command=SELECT_Curser_SELECT" does nothing with the NL/ML Converter. HOWEVER, it DOES work if I use a BeoPlay M5 as the renderer. But it does't work for an NL/ML Converter.
Anyone with any suggestions?
