Hi Kokomo, this is what you have to do:
Turn on tv and press Menu. Toggle down to SET UP, then press on your BEO4: GO, 0, 0, GO (all on your BEO4). You will acces a menu with 2 options. TV monitor and something about tuning. Select the first one. Then you will need ´Picture adjustments´. Once you acces that it will open a list and one of them is ´movie mode´. If you select that (GO on Beo4) you can choose between ON/AUTO/OFF (toggle Up and DOWN on BEO4). Try for yourself what it does to your picture and let me know what your opinion is. To leave the menu press STOP on your BEO4 repeatedly. Please remember that you do not store a different setup untill you are 100% sure about your choice and write down what you change in this menu!!! Hope this helps.
