Film mode on Beovision 3 32"
Hi guys, maybe someone can help me. I read about the Film mode on Beovisions and I am wondering if there is a possibility to turn it off on my BV3?  The number is 8810. Is there a way to do this by myself?
Gr. M.
Do you mean the 3 picture formats available?
No I don´t mean the formats. It´s about ´the film mode´ in the service menu. A lot of people are talking about it but I want to know where I can find this option inside the service menu from the Beovision 3.
  I had this option turned on on my avant I didn't like how the picture performs!  my friend the B&O engineer turned it off, I am sure someone on this site will know how to turn it off.
Cheers Nick
Yep no problem there; the option can be found in the Monitor part of the SM under picture adjustments.
Take your time, this is how it's done on type 8805 - should be the same -
With your Beo4, press: MENU, 3, 0, 0, GO, 1, 3, 9, (toggle between) ON / OFF, press GO  >  and EXIT out, being careful not to change anything else
Have you just started using the BV3? I turned it off when i first got it becasue it seems so different at first, but now i have it on, the picture is superior.
Hi Dave, I figured it out myself yesterday and that is indeed the way to do it. Only on the BV3 it is called ´movie mode´ and not ´film mode´. I have 3 option to install, ON/AUTO/OFF. I really don´t know what all this does to the screen (?) because I cannot notice huge differences. I also do not know if there is a difference between looking at tv or a dvd?? Is there anyone out there who can tell me the differences?
Gr,
I remeber accessing the service menu on my BV 3 a long time ago, but all the different settings frightened me so I quickly left before I was tempted to change something. Now I forgotten how to do it. Can someone tell me please?
Kokomo, it is mentioned above. Read Dave´s report (no. 4 from above)
Sorry for that, it is no. 5 from above..........:-))..........
Thanks Meng, but I immediately tried that before I posted and it didn't work! Menu, Menu,3 gets me set up but that's just for connections, sound, picture etc. I didn't think that was what was being referred to - or is it? I remember accessing a much more 'complicated' looking menu with lots of technical adjustments possible. It's that one I have forgotten how to access.
