Faulty MCL2A box and transceivers
See above... BTW, make sure you don't forget to power down the entire MCL bus before messing with the MCL wiring (unplug both the Beomaster and the wall wart of this extender box)! 😁 It's easy to forget...
Brilliant, thanks a lot for the advice! Now all I need to do is lift a few floorboards, drill a few holes in my floor and walls and get a couple of pairs of Beovox's. What a supercool project! Thanks again, Mika :)
