FAQ for B&O RF Link Amplifier
Keith Saunders wrote:
The RF Amplifier can be used to distribute any analogue TV signal so it can be used with the AVANT and Beovision 3 etc without problems.
Are there any differences in the RF modulators used in the various BV7 versions and the BV3/Avant?
David
ibg001 wrote:
My Dilog digital TV box have both SCART and HDMI and both are connected to the BV8-32. But I do not get any signal on the link frequency 599,25 mHz when I tune into this frequency in EyeTV. I do not have the RF Link Amplifier, but still there should be a signal from RF out? It is not just programmes from the external box I do not get any signal from via the RF out. There is also not signal from the internal DVB-T modul on RF-out.
What is wrong? Or was the person in the main Beostore in Copenhagen right when he said it is not possible with the 32'' version of BV8. Or do I need the RF link amplifier before it will work. I do not want to purchase the amplifier before I know it will work.
I am a bit frustrated.
I am using Linkplayer together with EyeTV on my Mac in the link room.
Has anyone tried with BV8-32?
Well my BV8-32 works.
I think you have to force the transmission - it does not happen automatically.
So I think you need to trick the BV8-32 into thinking there is a link TV out there.
From memory there is a setting in the BV8-32 where you can indicate how the RF signal is to be treated
edited
Try this
[DTV]
[MENU]
[4]
(OPTIONS)
(ACTIVE ANTENNA) > (ON)
[GO]
[EXIT]
Active Antenna is something else. This is used to send 5 volt power to an external antenna amplifier. The power is then send out to the antenne in socket.
ibg001 wrote:
oh, ok.
so how did you go trying to generate a link room video command to the BV8-32 ?
I have probably found something. In Settings where you also can change the link frequency you can also activate the RF modulator. It is by defualt set to auto, but if you do no use a Bevisio TV in the link room the modulator will not be activated automatically.
I have not tested this yet.
hi,
i think i have understood the technical aspects of the rfla, or at least the basics...
i am curious to know how it functions from a user point of view. if i set things up correctly i should get my tv channels and bluray player output (as an example) running down the same cable.
but how does it appear to the user. is the bluray player output seen as an additional channel ? or does it automatically switch to the signal once the bluray player is activated and remain "invisible" the rest of the time ?
this may seem like a silly question. but i am currently using a lexcom box to integrate a media player signal into my tv channels and it simply shows up as an extra tv channel .
thanks for your help !
- scott
Yes !
That's the setting I confused with the "Active Antenna".
I too find this area confusing -- so you still may need a link room signal to trigger things.
For me (I have some old, non-B&Os CRTs as my link room TVs) the behaviour is as follows:
-- the TVs are tuned into Australia's 5 standard analogue TV signals that I believe the RF Amplifier is re-broadcasting from my roof aerial, I switch between these using the TVs non-B&O remote and the audio comes from the TVs
-- the CRT TVs are also tuned to a sixth channel which is the link frequency of the mb BV8-32
Now assume I have switched on a CRT TV to the link frequency
-- if I use my Beo4 in the link rooms and I press [TV] I get the standard analogue channel re-broadcast from the BV8-32, and my Beo4 up [ ^ ] & down [ v ] buttons change the analogue channels that the BV8 is transmitting on the link frequency ... my audio is coming from the CRT's channels AND from the link room's BeoLabs
-- if I use my Beo4 in the link rooms and I press [DTV] I get the standard Australian FreeView digital channel re-broadcast from the BV8-32, and my Beo4 up [ ^ ] & down [ v ] buttons change the digital channels inside the BV8 and a new show appears on the CRT's link frequency channel ... my audio is coming from the CRT's channels AND from the link room's BeoLabs ... the Beo4's volume control only changes the BeoLabs and not the CRT's speaker
-- if I use my Beo4 in the link rooms and I press the soft button [V-AUX] I get whatever my Foxtel box is tuned to re-broadcast from the BV8-32, and my Beo4 up [ ^ ] & down [ v ] buttons change the Foxtel's channels, and I can interact with its menus (via [MENU] etc) ... my audio is coming from the CRT's channels AND from the link room's BeoLabs
-- if I use my Beo4 in the link rooms and I press [DVD] I get the DVD re-broadcast from the BV8-32, and my Beo4 buttons control the DVD player ... my audio is coming from the CRT's channels AND from the link room's BeoLabs
I really set this all up as an experiment to see how it all works and to enable my sons to use the CRTs for their late night watching or for watching when they were working in their rooms, but for my wife and I 99.99% of our TV watching was with the BV8-32 ... now that we have an iPad in the house we use that as a small portable TV, but there we are leveraging the MacMini and its Elgato eyeTV which is connected/tuned into one of the RF Amplifiers 4 output cables
I have now tried with no success. I have installed a Bang & Olufsen RF Link amplifier. Så the setup is now now. The aerial is connected directly to the RF link amplifier. RF out from the BV 8-32 to the "mod in" on the RF amplifier. The digital settop box to tap 2 on the RF link amplifier. The link room is connect to tap3.
In the main room every thing works. The Set top box is activated with V.AUX and this work. The DVD works fine. In the link room the aerial signal is fine, and can tune EyeTV in to all free channels. In Eye TV I have setup a analogue channel in EyeTV on the frequency 599,25 (Link), but there is no signal on the link frequency.
In setting (TV > MENU > setting. I have checked the link frequency and it is 599 mHz. I have been told to change the modulator setting from "Auto" to "On", since it is only Bang & Olufsen equipment that can turn it on automatically, but the weird thing is. I press "go" to save the settings and open to menu again to check the setting is then altered back to "Auto" Why does the BV8-32 not keep the setting. Why?
I used all the taps on my RF Amplifier, I just tried to check what goes with what but the rats' nest of wires prevents me from tracing everything, but it sounds like that part is wired correctly.
I set my link frequency to 450, mainly because I was having trouble detecting the signal and I thought I might be dealing with an issue where the link frequency was above the frequency range that the TVs of my country were expecting.  My other setting is "B/G".
I too have noticed that annoying reset from MANUAL to AUTO but I think that is OK.
How are you getting a link room command to get to the BV8 to trigger its operation ?
