Hey guys would love some help as I'm looking to buy the Playmaker. Here is my scenario as I would like some advice , as the title says I rang around today and got so man different answers in how to link my system up , here goes.
I have a set of 8000 speakers connected to my B&O 3200. All is well.
I have since purchased a new Sony Bravia 6Oinch LED. I would like to connect my speakers into my speakers and still be able to use the 3200.
Four stores around Australia told me it can't be done.
One store said to run it through the TV headphone jack into the rear of my 3200
One store said to run an RCA cable from my TVs Audio out ( single 3.5mm jack , no optical , no Red/ White plug) into the 3200 ( same as above pretty much)
Finally one store recommended the following. RCA out from the TV into the two points of the Playmaker. Leave the speaker and 3200 plugged in as is. From the 3200 purchase a Din 8 ( RJ45 cable to RJ45 cable) plug one end into the Playmaker. With the other end remove the middle pin ( making it a 7 pin ) plug this into the 3200s Aux port
It's been pretty tricky getting a straight answer and if the final result will actually work.
I just wanted to avoid running a cable from my TV hanging on the wall to my 3200 as it looks messy being a big distance and and wanted to avoid usin the headphone jack as I may have to enter the headline menus to turn up the volume.
There were a few other ideas regarding optical cables but neither my TV or 3200 ( that I can see ) have optical ( TV 100% does not ).
the other idea I was tossing up was just buying Apple Airport Express. But I'm a little stumped on how I would plug this into my TV and get my speakers still hooked up to my 3200 to play.
Futhure more I have been told there is a new Playmker on its way available for order now.
So really I have no idea how to proceed. Any help or advice would be greatly appreciated.
Thanks Steve
