I'm a german user and my english is not so good. I have this situation:
I have a B&O system (BV7, BV10, BV11, BM5, BS5, 1641 converter) with some rooms connected via ML/MCL I want to renew my old BV7 with a new LG-panel. But then I remove my BV7 I loose the daily timer function what switch on the radio on my BS5 in some rooms. I do not want to loose that. Any ideas how to implement a "external" timer what can substitute the BV7 timer. Sending an IR signal seams not possible. Think solution is to be to give a electric signal to the ML/MCL bus. But from where? Any suggestions if there is any solution for that ?
kind regards
Henri
