External Center speaker with v1/v11
Is it possible to configure v1 and v11 to use an external centre speaker? E.g. beolab 7.2
And if, why would you do that?
Greetings Millemissen
I have a 7.2 speaker built into my bedroom so would use it as center speaker as opposed to the built in internal speakers
As for the V1, I just checked, you can define a speaker group and assign the role "center" to any speaker you like. Additionally you set the role of the internal speakers "front left" and "front right" to off. I think the way to this, will be quite the same for the BV11.
hfat
PS:
I use a BL7.2 as center and I'm very pleased with it.
Oh that's good to here thanks!
I am still wondering 'why'?
