Extending masterlink via cat 6
i think yes.
look at this :
Sorry, this will not work. You will need Cat7 to complete the run with the appropriate adaptors. You need the braided shield that isn't present in Cat6.
The difference in bandwidth between Cat 6 or Ca 7 is not important, if you want to use
Cat x instead of original ML.
It's the layout of the shielding/screening of the cable that matters!.
To replace an original ML cable ONLY cables described as "S/FTP" =
"Shielded(Screened) /Foiled Twisted Pairs" have sufficent shielding for the
two Twisted "Audio" Pairs (carrying the BALANCED ANALOGE signals of ML)
to avoid crosstalk between these pairs and the 3rd Twisted ML "Data" Pair.
Ebay Germany seems a lot cheaper than ebay.fr....
Search for masterlink rj 45 on ebay.de
Ralf
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
