If you are using a BL active you connect your Beolabs to Powerlink of the active. You control all your sources via BL active.
If you are "creating" a musicroom with BS900, BS5 and BL5 you masterlink the 9000 and BS5 and connect BL5 to Powerlink and spdif to your BS9000. That`s what I would do...
Stefan
after reading this very interesting forum for a weekend that's also my conclusion.
BUT, I have the following problems:
- Beosound 5 control is to be placed next to a Beovsion 7, this is next to the room where I will place the Beolab 5.
- all the rooms are somewhat in 1 very large open space with little walls between. I think I will have problems with the control and will have to use the IR-range reducers as used in the B&O stores.
Therefore, I'm planning:
Room 1 : Beovision 7-40 with Beolab 7 and BeoMaster 5 - BeoSound 5
Room 2 : Beolink Active with 2 x BeoLab 6000
Room 3 : BeoSound 9000 digital and Powerlinked with BeoLab 5 (but I will not buy the BeoLab's this year, so firstly no speakers connected to the BS9000)
Room 4 : BeoVision 10-40"
Room 5 : BeoLab 35000
Room 6 : BeoVision 7 or 8 with left and right speakers
Will all rooms have access to all the sources and control them ?
Control-problem is : Rooms 1, 2, 3 and 4 are in 1 large room with little walls. For example, the Beovision 10-40" is also visible in room 2. To solve this I will place the IR-eye of the Beolink active in a corner, out of sight of the Beovision 10-40.
Or is there an other solution ?
Thanks for all your help
