Essence MK 2 received.
Shut the phone down and do the restart so that you get the Apple logo at the restart..  2 buttones to close the phone down etc.  Or whatever it takes for your iPhone.
Dave.
It now works when i am not connected to wifi, but as soon as i connect it's fails!
I speak to my dealer today and it seems to be a bug in the BeoMusic software.. The problem is that it wan't at work with Norwegian text using my iPhone 6, so when i switch to example Danish, everything woks fine..
But should't i also se my BLC on the App?
OMG a racist software bug!  What a bizarre thing to find out.  I hope they can fix that in an upcoming update.  How's your Danish?
Dave.
It'så almost the same as Norwegian, so i Can handel it for some days ;)
BeoMusic v.2.0.1 was just released to the App Store, and it fixes the issue with the Norwegian language.
Petros
Petros
JIPPi :)
Good Morning,
Is it possible to use the MK2 with the external IR-Receiver and the new Beoremote One? MK1 only works with the old Beo4 - as the B&O FAQ says....
Regards
tradingman wrote:
Good Morning,
Regards
Back to the thread's title ... Mine has arrived and is waiting for me ... By the end of the weekend I may have some answers for you !
elephant wrote:
Back to the thread's title ... Mine has arrived and is waiting for me ... By the end of the weekend I may have some answers for you ! BeoNut since '75
Thanks 😁
