One would hope so !Unrelated question: Is the A9 90 year edition a Mk2?
Essence MK 2 received.
Am I the only one who has the problem with Deezer in the App?
It won't register me as a Premium member, so when I use the BeoMusic App I can only play 30 seconds clip?
One would hope so !
Yes it is, I have it.
I have now updated the BeoMusic app, but i can not open it.. It want even start on my iPhone 6.
Anyone else has the same problem?
I have deleted the app and installed it again, but the same problem...
Your dealer is correct. Spotify can be distributed, among NL products that support Spotify Connect. See screens below:
1. You start, via the Spotiy App, playing to one of the Spofity Connect products
2. Via the BeoMusic App, you can expand to other products
3. Even the UI of the Spotify App is updated, and it shows that the two (or more) Spotify Connect products are now grouped in a multiroom session
Petros
Cool !By the way Petros I don't recall seeing your posts before - so welcome and thank you - the posts are very informative3. Even the UI of the Spotify App is updated, and it shows that the two (or more) Spotify Connect products are now grouped in a multiroom session
Yes, cool indeed - maybe I could use another Essence..
Try a hard shut down of the phone and restart it. I had a problem between Essence and other apps and a restart of the IOS device fixed it.
Dave.
Hi.
What do you mean by hard shut down? I have tried to restart it, but same problem.. Really strange ...
@petrosbeli
Thanks!
