Martin wrote:
If start Spotify and then stop it by useing the wheel. Can i start it again with the wheel and not have to play tennis with apps and devices? Is the multiroom making the essence hard and not easy to use for users with only one b&o device?
Yes, you can start it again directly from the product. When you press
the "sound" button of the Essence Remote (i.e. the top button of the
"wheel"), you get to toggle among the sound sources, with the following
order:
1. TuneIn Internet Radio
2. Deezer (or DLNA)
3. Spotify Connect
4. Line In
If you dont have a source (e.g. Deezer) it is automatically skipped.
So,
in your case, starting the BeoSound Essence from stand by will
initially play TuneIn (first press). And then with one more press it
will play Spotify Connect, where you left it at.
The same logic
applies also to the BeoPlay A9 (2nd gen.), but there you are simply
"tapping" the product on its back (touch sensor).
Finally, if
there is any other already on-going experience in your BeoLink Multiroom
system (i.e. a system with more than one product), the first "press" or
"tap" will actually join the on-going experience. The subsequent
press/taps will toggle the sources as above.
Petros
