Normal 0 false false false MicrosoftInternetExplorer4 <!-- /* Font Definitions */ @font-face {font-family:SimSun; panose-1:2 1 6 0 3 1 1 1 1 1; mso-font-alt:宋体; mso-font-charset:134; mso-generic-font-family:auto; mso-font-pitch:variable; mso-font-signature:3 680460288 22 0 262145 0;} @font-face {font-family:"\@SimSun"; panose-1:2 1 6 0 3 1 1 1 1 1; mso-font-charset:134; mso-generic-font-family:auto; mso-font-pitch:variable; mso-font-signature:3 680460288 22 0 262145 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:SimSun;} p {mso-margin-top-alt:auto; margin-right:0cm; mso-margin-bottom-alt:auto; margin-left:0cm; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:SimSun;} @page Section1 {size:612.0pt 792.0pt; margin:70.85pt 70.85pt 70.85pt 70.85pt; mso-header-margin:36.0pt; mso-footer-margin:36.0pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
I
bought a house with an existing B&O installation, which I am trying
to figure out how to get working again. The problem is that a previous
owner has taken most of the equipment with him and I am left with the
cable installation, some passive loudspeakers and IR receivers.
Three
rooms (bedroom, hall and library) have a pair of passive speakers (Jamo
Art) controlled be a square IR receiver (type 2047). The living room
has a circular eye and outlets for a pair of active speakers. All the
cables connect to the library, which served as the main room. There is
also a ML cable from the library to the kitchen. The ML cable has three
ML connectors wired in parallel in the library. From the end point in
the kitchen, there are passive loudspeaker cables and a cable for an IR
eye placed outdoors under a roof close to the pool. The actual IR-eye
is removed by a previous house owner.
I have figured out that to
get the outdoors speakers to work in a B&O system I need the
Beolink Passive control box and an outdoor case and a new IR eye. To
get a pair of active speakers to be controlled by the existing IR eye
in the living room I need a Beolink Active control box.
But for
the other three passive speakers I have not figured out what equipment
to use. I have read that 2047 is part of the MCL X-TRA Speaker Kit with
the MCL 2A relay box. The cable end of the 2047 cable which should
connect to the MCL2A relay box does not have connectors attached, which
makes me thinking that the previous owner might have made some
home-made connection with these cables.
I have not purchased any
equipment yet for the main room/library, so from that perspective I am
open to using e.g. older equipment with built-in amplifiers if that
would help.
Do you know what would be the best alternative to get the passive loudspeakers to work with a minimum of equipment?
